Ana içeriğe geç
Dell Precision 7560 Keyboard Replacement
Neye ihtiyacın var
  1. Dell Precision 7560 Keyboard Replacement, Battery: adım 1, 3 resimden 1. Dell Precision 7560 Keyboard Replacement, Battery: adım 1, 3 resimden 2. Dell Precision 7560 Keyboard Replacement, Battery: adım 1, 3 resimden 3.
    • The screws holding the back cover in place can not be removed.
    • Use a Phillips #0 screwdriver to loosen the the eight 5 mm captive screws in the bottom cover.
    • Remove the back cover by lifting at the corners.
  2. Dell Precision 7560 Keyboard Replacement: adım 2, 3 resimden 1. Dell Precision 7560 Keyboard Replacement: adım 2, 3 resimden 2. Dell Precision 7560 Keyboard Replacement: adım 2, 3 resimden 3.
    • Unscrew and remove the five 2 mm screws that secure the battery.
    • Locate the battery connector.
  3. Dell Precision 7560 Keyboard Replacement: adım 3, 3 resimden 1. Dell Precision 7560 Keyboard Replacement: adım 3, 3 resimden 2. Dell Precision 7560 Keyboard Replacement: adım 3, 3 resimden 3.
    • Pull the connector towards you to disconnect it.
    • Use your fingers or a plastic opening tool to pry the battery up and remove it from the laptop.
  4. Dell Precision 7560 Keyboard Replacement, Keyboard: adım 4, 3 resimden 1. Dell Precision 7560 Keyboard Replacement, Keyboard: adım 4, 3 resimden 2. Dell Precision 7560 Keyboard Replacement, Keyboard: adım 4, 3 resimden 3.
    • With the back cover and battery removed, locate the ribbon cables connected to the keyboard.
    • Pulling from the tab, carefully remove the connector.
  5. Dell Precision 7560 Keyboard Replacement: adım 5, 3 resimden 1. Dell Precision 7560 Keyboard Replacement: adım 5, 3 resimden 2. Dell Precision 7560 Keyboard Replacement: adım 5, 3 resimden 3.
    • Turn the device over and open the screen to expose the keyboard.
    • Using an opener tool, pry along the edges of the keyboard to remove the keyboard's plate cover.
  6. Dell Precision 7560 Keyboard Replacement: adım 6, 3 resimden 1. Dell Precision 7560 Keyboard Replacement: adım 6, 3 resimden 2. Dell Precision 7560 Keyboard Replacement: adım 6, 3 resimden 3.
    • With the plate cover removed, use the screwdriver to remove each of the six 2 mm screws.
    • Carefully remove the keyboard from the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jack Allred
336 İtibar
2 adet Kılavuz yazıldı
Ekip
Bir Yorum
Guide is close, but not completely correct. Just need a little more attention to detail.
Barry Todd - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 13
Son 30 gün: 56
Her zaman: 738
