Ana içeriğe geç
Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement
Neye ihtiyacın var
  1. Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement, NVMe Solid-State Drive (Expansion): adım 1, 3 resimden 1. Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement, NVMe Solid-State Drive (Expansion): adım 1, 3 resimden 2. Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement, NVMe Solid-State Drive (Expansion): adım 1, 3 resimden 3.
    • The screws holding the back cover in place can not be removed.
    • Use a Phillips #0 screwdriver to loosen the eight 5 mm captive screws in the bottom cover.
    • Remove the back cover by lifting at the corners.
  2. Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement: adım 2, 2 resimden 1. Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement: adım 2, 2 resimden 2.
    • Use the Phillips #0 screwdriver to unscrew and remove the two 2 mm screws that secure the expansion NVMe SSD sticks.
  3. Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement: adım 3, 2 resimden 1. Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement: adım 3, 2 resimden 2.
    • Disconnect the left SSD stick by pulling its exposed end towards you.
    • Repeat the same procedure to the right SSD stick.
Sonuç
Hector
261 İtibar
2 adet Kılavuz yazıldı
Ekip
1Rehber Yorum
This is not for RAM this is for the SSD upgrades.
Kurtis - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 36
Her zaman: 535
