Ana içeriğe geç
Dell Precision 7560 Screen Replacement
Neye ihtiyacın var
  1. Dell Precision 7560 Screen Replacement, Screen: adım 1, 3 resimden 1. Dell Precision 7560 Screen Replacement, Screen: adım 1, 3 resimden 2. Dell Precision 7560 Screen Replacement, Screen: adım 1, 3 resimden 3.
    • Using an opener tool, pry open the bezel, following along the screen's perimeter.
    • Lightly pull from the corners to remove the bezel.
  2. Dell Precision 7560 Screen Replacement: adım 2, 2 resimden 1. Dell Precision 7560 Screen Replacement: adım 2, 2 resimden 2.
    • Use the Phillips #0 screwdriver to remove:
    • Two 2 mm screws from the top screen brackets.
    • Two 3 mm screws from the bottom screen brackets.
    • Once these screws are removed, you should be able to gently pry the laptop screen free.
    • Be careful not to apply too much pressure, as this could damage the screen or other components inside the laptop.
  3. Dell Precision 7560 Screen Replacement: adım 3, 3 resimden 1. Dell Precision 7560 Screen Replacement: adım 3, 3 resimden 2. Dell Precision 7560 Screen Replacement: adım 3, 3 resimden 3.
    • To fully disconnect the screen, gently peel off the white tape that secures the video connector.
    • Remove the blue tape that lies between the white tape and the video connector.
    • Open the video connector's bracket and remove the cable, pulling towards the back of the device.
Sonuç
Laisha
205 İtibar
2 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 62
Her zaman: 1,078
