Ana içeriğe geç
Dell Precision 7560 Solid-State Drive (SSD) Replacement
Neye ihtiyacın var
  1. Dell Precision 7560 Solid-State Drive (SSD) Replacement, Battery: adım 1, 3 resimden 1. Dell Precision 7560 Solid-State Drive (SSD) Replacement, Battery: adım 1, 3 resimden 2. Dell Precision 7560 Solid-State Drive (SSD) Replacement, Battery: adım 1, 3 resimden 3.
    • The screws holding the back cover in place can not be removed.
    • Use a Phillips #0 screwdriver to loosen the the eight 5 mm captive screws in the bottom cover.
    • Remove the back cover by lifting at the corners.
  2. Dell Precision 7560 Solid-State Drive (SSD) Replacement: adım 2, 3 resimden 1. Dell Precision 7560 Solid-State Drive (SSD) Replacement: adım 2, 3 resimden 2. Dell Precision 7560 Solid-State Drive (SSD) Replacement: adım 2, 3 resimden 3.
    • Unscrew and remove the five 2 mm screws that secure the battery.
    • Locate the battery connector.
  3. Dell Precision 7560 Solid-State Drive (SSD) Replacement: adım 3, 3 resimden 1. Dell Precision 7560 Solid-State Drive (SSD) Replacement: adım 3, 3 resimden 2. Dell Precision 7560 Solid-State Drive (SSD) Replacement: adım 3, 3 resimden 3.
    • Pull the connector towards you to disconnect it.
    • Use your fingers or a plastic opening tool to pry the battery up and remove it from the laptop.
  4. Dell Precision 7560 Solid-State Drive (SSD) Replacement, Solid-State Drive (SSD): adım 4, 2 resimden 1. Dell Precision 7560 Solid-State Drive (SSD) Replacement, Solid-State Drive (SSD): adım 4, 2 resimden 2.
    • Unscrew and remove the two 3 mm screws that secure the solid-state drive.
  5. Dell Precision 7560 Solid-State Drive (SSD) Replacement: adım 5, 2 resimden 1. Dell Precision 7560 Solid-State Drive (SSD) Replacement: adım 5, 2 resimden 2.
    • Remove the top cover of the Solid State Drive by lifting up from the corners.
    • Notice that the Solid State Drive is located underneath the cover.
    • Pull the Solid State Drive gently towards you from its exposed end to disconnect it.
    • With an appropriate replacement part, exchange the old SSD with a new one.
Sonuç
Hector
249 İtibar
2 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 47
Her zaman: 490
