Ana içeriğe geç
Dell Precision 7560 Speaker Replacement
Neye ihtiyacın var
  1. Dell Precision 7560 Speaker Replacement, Battery: adım 1, 3 resimden 1. Dell Precision 7560 Speaker Replacement, Battery: adım 1, 3 resimden 2. Dell Precision 7560 Speaker Replacement, Battery: adım 1, 3 resimden 3.
    • The screws holding the back cover in place can not be removed.
    • Use a Phillips #0 screwdriver to loosen the the eight 5 mm captive screws in the bottom cover.
    • Remove the back cover by lifting at the corners.
  2. Dell Precision 7560 Speaker Replacement: adım 2, 3 resimden 1. Dell Precision 7560 Speaker Replacement: adım 2, 3 resimden 2. Dell Precision 7560 Speaker Replacement: adım 2, 3 resimden 3.
    • Unscrew and remove the five 2 mm screws that secure the battery.
    • Locate the battery connector.
  3. Dell Precision 7560 Speaker Replacement: adım 3, 3 resimden 1. Dell Precision 7560 Speaker Replacement: adım 3, 3 resimden 2. Dell Precision 7560 Speaker Replacement: adım 3, 3 resimden 3.
    • Pull the connector towards you to disconnect it.
    • Use your fingers or a plastic opening tool to pry the battery up and remove it from the laptop.
  4. Dell Precision 7560 Speaker Replacement, Solid-State Drive (SSD): adım 4, 2 resimden 1. Dell Precision 7560 Speaker Replacement, Solid-State Drive (SSD): adım 4, 2 resimden 2.
    • Unscrew and remove the two 3 mm screws that secure the solid-state drive.
  5. Dell Precision 7560 Speaker Replacement: adım 5, 2 resimden 1. Dell Precision 7560 Speaker Replacement: adım 5, 2 resimden 2.
    • Remove the top cover of the Solid State Drive by lifting up from the corners.
    • Notice that the Solid State Drive is located underneath the cover.
    • Pull the Solid State Drive gently towards you from its exposed end to disconnect it.
    • With an appropriate replacement part, exchange the old SSD with a new one.
  6. Dell Precision 7560 Speaker Replacement, Speaker: adım 6, 3 resimden 1. Dell Precision 7560 Speaker Replacement, Speaker: adım 6, 3 resimden 2. Dell Precision 7560 Speaker Replacement, Speaker: adım 6, 3 resimden 3.
    • Loosen the eight captive screws that secure the fan assembly using a Phillips #0 screwdriver.
    • Lifting from the bottom, carefully remove the fan.
  7. Dell Precision 7560 Speaker Replacement: adım 7, 3 resimden 1. Dell Precision 7560 Speaker Replacement: adım 7, 3 resimden 2. Dell Precision 7560 Speaker Replacement: adım 7, 3 resimden 3.
    • Remove the 5 mm screw holding the Wi-Fi card in place using a Phillips #0 screwdriver.
    • Remove the metal overlay.
    • Disconnect the wires attached to the Wi-Fi card.
    • Remove the Wi-Fi card.
  8. Dell Precision 7560 Speaker Replacement: adım 8, 2 resimden 1. Dell Precision 7560 Speaker Replacement: adım 8, 2 resimden 2.
    • Remove the 2 mm screws holding the metal frame in place using a Phillips #0 screwdriver.
    • Remove, carefully and completely, any wires running over the frame.
    • Lift the metal frame.
  9. Dell Precision 7560 Speaker Replacement: adım 9, 2 resimden 1. Dell Precision 7560 Speaker Replacement: adım 9, 2 resimden 2.
    • Flip up the metal edge holding down the SD connection.
    • Gently pull to disconnect the metal connecting wire.
  10. Dell Precision 7560 Speaker Replacement: adım 10, 3 resimden 1. Dell Precision 7560 Speaker Replacement: adım 10, 3 resimden 2. Dell Precision 7560 Speaker Replacement: adım 10, 3 resimden 3.
    • Remove the 5 mm screw holding the metal cap over the wire connection using a Phillips #0 screwdriver.
    • Remove the metal cap.
    • Disconnect the wire bundle.
  11. Dell Precision 7560 Speaker Replacement: adım 11, 3 resimden 1. Dell Precision 7560 Speaker Replacement: adım 11, 3 resimden 2. Dell Precision 7560 Speaker Replacement: adım 11, 3 resimden 3.
    • Using a Phillips #0 screwdriver, remove the eight 2 mm screws holding the motherboard.
    • Carefully remove the speaker wire from the motherboard.
  12. Dell Precision 7560 Speaker Replacement: adım 12, 2 resimden 1. Dell Precision 7560 Speaker Replacement: adım 12, 2 resimden 2.
    • Using both hands, carefully lift and remove the speaker.
Sonuç
Neevia Vinod
145 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 17
Her zaman: 137
