Ana içeriğe geç
Dell Precision 7560 Wi-Fi Card Replacement
Neye ihtiyacın var
  1. Dell Precision 7560 Wi-Fi Card Replacement, Wi-Fi Card: adım 1, 1 resimden 1.
    • Use a Phillips #0 screwdriver to loosen the eight 5 mm captive screws in the bottom cover.
    • The screws holding the back cover in place can not be removed.
  2. Dell Precision 7560 Wi-Fi Card Replacement: adım 2, 2 resimden 1. Dell Precision 7560 Wi-Fi Card Replacement: adım 2, 2 resimden 2.
    • Pry off the back cover using an iFixit opening tool.
  3. Dell Precision 7560 Wi-Fi Card Replacement: adım 3, 1 resimden 1.
    • Remove the 2 mm screw securing the wire cover using a Phillips #0 screwdriver.
  4. Dell Precision 7560 Wi-Fi Card Replacement: adım 4, 1 resimden 1.
    • Carefully detach the black and white wires from the Wi-Fi card.
  5. Dell Precision 7560 Wi-Fi Card Replacement: adım 5, 1 resimden 1.
    • Pull and lift the Wi-Fi card to remove it.
Sonuç
Joshua Seo
121 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 60
