Neye ihtiyacın var
Slide the release latch to unlock the battery cover [1].
Slide and lift the battery cover to remove it from the computer [2].
Slide the release latch to unlock the battery [1].
Lift and remove the battery from the computer [2].
Lift the tab and disconnect the 4 cables, one of the cables may be obstructed by the HDD, so you will need to unscrew/detatch the HDD tray first [1, 2].
Pry the keyboard trim starting from the bottom and work along the top edge and remove it from the computer.
Sonuç
