Ana içeriğe geç
Dell Precision M2400 Memory Module Replacement
Neye ihtiyacın var
  1. Dell Precision M2400 Memory Module Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the battery release latches toward each other to lock them in an open position.
    • Slide the battery out of the battery bay.
    FixBot'a Sor
    Yorum Ekle
  2. Dell Precision M2400 Memory Module Replacement, Base Cover: adım 2, 1 resimden 1.
    • Loosen the captive screw.
    • Slide the bottom of the base assembly away from the hinge covers, and lift to remove the bottom of the base assembly.
    FixBot'a Sor
    Yorum Ekle
  3. Dell Precision M2400 Memory Module Replacement, Memory Module: adım 3, 1 resimden 1.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
    • Remove the memory module from the connector.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Johnathan Hammond
46.149 İtibar
408 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
45 Üyeler
2.003 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 21
Her zaman: 234
