Ana içeriğe geç
Dell Precision M3800 Fan Replacement
Neye ihtiyacın var
  1. Dell Precision M3800 Fan Replacement, Back Cover: adım 1, 2 resimden 1. Dell Precision M3800 Fan Replacement, Back Cover: adım 1, 2 resimden 2.
    • Be sure to power off and unplug your device before you begin your repair.
    • Use a T5 Torx screwdriver to unscrew the ten 3mm screws on the laptop back cover.
    • iFixit’s magnetic project mat is great for keeping the screws in one place.
    • Lift up the silver cover from the back panel to reveal two screws.
    • Use a Phillips screwdriver to remove the two screws underneath the silver cover.
    FixBot'a Sor
    Yorum Ekle
  2. Dell Precision M3800 Fan Replacement: adım 2, 1 resimden 1.
    • Use an opening tool to pry around the edges of the back panel to loosen the panel.
    • Remove the back panel.
    FixBot'a Sor
    Yorum Ekle
  3. Dell Precision M3800 Fan Replacement, Fan: adım 3, 2 resimden 1. Dell Precision M3800 Fan Replacement, Fan: adım 3, 2 resimden 2.
    • Use a Phillips #00 screwdriver to unscrew the two 3.5mm screws that are holding the fans in place.
    FixBot'a Sor
    Yorum Ekle
  4. Dell Precision M3800 Fan Replacement: adım 4, 3 resimden 1. Dell Precision M3800 Fan Replacement: adım 4, 3 resimden 2. Dell Precision M3800 Fan Replacement: adım 4, 3 resimden 3.
    • Using a nonmetal prying tool, unplug the cord connecting the fan to the motherboard.
    • If replacing the right fan, this cord is located underneath the fan.
    • If replacing the left fan, this cord is located on the left of the fan.
    FixBot'a Sor
    Yorum Ekle
  5. Dell Precision M3800 Fan Replacement: adım 5, 2 resimden 1. Dell Precision M3800 Fan Replacement: adım 5, 2 resimden 2.
    • Use nonmetal prying tool to lift the bottom of the fan from the laptop body (this will require some force and you will hear an adhesive pulling sound).
    • Repeat the steps for the second fan if needed .
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 20
Her zaman: 1,747
