Giriş
Overtime, every electronic device is going to experience some wear and tear. In some cases, if the volume is too high, the speakers of your device may become faulty. If the Dell Precision M3800 speakers are giving little to no audio or audio that is scratchy or distorted, use this guide to replace the faulty speakers.
Before beginning, be sure to power down the laptop, and unplug from the external power source(s).
Neye ihtiyacın var
Use a T5 Torx screwdriver to unscrew the ten 3mm screws on the laptop back cover.
Lift up the silver cover from the back panel to reveal two screws.
Use a Phillips screwdriver to remove the two screws underneath the silver cover.
Disconnect the battery cable from the system board [1].
Use a Phillips screwdriver to remove the four screws securing the battery to the laptop.
Lift the battery off the computer [2].
Unplug the red, white, and blue speaker wire connected to the main motherboard.
Bir başkası bu kılavuzu tamamladı.
