Ana içeriğe geç
Dell Precision M3800 Touch Pad Replacement
Neye ihtiyacın var
  1. Dell Precision M3800 Touch Pad Replacement, Back Cover: adım 1, 2 resimden 1. Dell Precision M3800 Touch Pad Replacement, Back Cover: adım 1, 2 resimden 2.
    • Be sure to power off and unplug your device before you begin your repair.
    • Use a T5 Torx screwdriver to unscrew the ten 3mm screws on the laptop back cover.
    • iFixit’s magnetic project mat is great for keeping the screws in one place.
    • Lift up the silver cover from the back panel to reveal two screws.
    • Use a Phillips screwdriver to remove the two screws underneath the silver cover.
  2. Dell Precision M3800 Touch Pad Replacement: adım 2, 1 resimden 1.
    • Use an opening tool to pry around the edges of the back panel to loosen the panel.
    • Remove the back panel.
  3. Dell Precision M3800 Touch Pad Replacement, Battery: adım 3, 1 resimden 1.
    • Disconnect the battery cable from the system board [1].
    • Use a Phillips screwdriver to remove the four screws securing the battery to the laptop.
    • Lift the battery off the computer [2].
  4. Dell Precision M3800 Touch Pad Replacement, Touch Pad: adım 4, 3 resimden 1. Dell Precision M3800 Touch Pad Replacement, Touch Pad: adım 4, 3 resimden 2. Dell Precision M3800 Touch Pad Replacement, Touch Pad: adım 4, 3 resimden 3.
    • Remove the wire that connects the touch pad with the motherboard with a hooked pry tool (Spudger 3) and by pulling the pull tab to safely remove the wire.
  5. Dell Precision M3800 Touch Pad Replacement: adım 5, 2 resimden 1. Dell Precision M3800 Touch Pad Replacement: adım 5, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the two 2mm silver screws.
  6. Dell Precision M3800 Touch Pad Replacement: adım 6, 1 resimden 1.
    • Remove the touch pad from the laptop. If needed, use a prying tool to remove the touch pad.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 21
Her zaman: 987
