Ana içeriğe geç
Dell Precision M4400 Memory Module Replacement
Neye ihtiyacın var
  1. Dell Precision M4400 Memory Module Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the battery release latches to the open position. (The latches lock into place).
    • Grip the battery and slide it out of the battery bay.
    FixBot'a Sor
    Yorum Ekle
  2. Dell Precision M4400 Memory Module Replacement, Base Cover: adım 2, 1 resimden 1.
    • Loosen the M2.5 x 5-mm captive screw.
    • Using the rubber feet for leverage, slide the bottom of the base assembly toward the front of the computer 1/8th inch, then lift to remove it.
    FixBot'a Sor
    Yorum Ekle
  3. Dell Precision M4400 Memory Module Replacement, Memory Module: adım 3, 1 resimden 1.
    • To remove the DIMM module, spread away the retaining clips from the side edges of the memory module and lift the free edge of the module so that it sits at about a 30-degree angle to the system board.
    • Grasp the module at the side edges and pull it straight away from the connector. Place the module into anti-static packaging such as an anti- static bag.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Johnathan Hammond
46.149 İtibar
408 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
45 Üyeler
2.003 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 26
Son 30 gün: 53
Her zaman: 717
