Ana içeriğe geç
Dell Precision M4600 Memory Module Replacement
Neye ihtiyacın var
  1. Dell Precision M4600 Memory Module Replacement, Battery: adım 1, 2 resimden 1. Dell Precision M4600 Memory Module Replacement, Battery: adım 1, 2 resimden 2.
    • Slide the battery release latch into the unlock position.
    • Remove the battery from the system.
    FixBot'a Sor
    Yorum Ekle
  2. Dell Precision M4600 Memory Module Replacement, Base Cover: adım 2, 3 resimden 1. Dell Precision M4600 Memory Module Replacement, Base Cover: adım 2, 3 resimden 2. Dell Precision M4600 Memory Module Replacement, Base Cover: adım 2, 3 resimden 3.
    • Remove the screws that secure the base cover to the computer.
    • Press the rubber feet towards the rear of the system to disengage the bottom door.
    • Remove the base cover from the computer.
    FixBot'a Sor
    Yorum Ekle
  3. Dell Precision M4600 Memory Module Replacement, Keyboard Trim: adım 3, 3 resimden 1. Dell Precision M4600 Memory Module Replacement, Keyboard Trim: adım 3, 3 resimden 2. Dell Precision M4600 Memory Module Replacement, Keyboard Trim: adım 3, 3 resimden 3.
    • Using a plastic scribe, pry under the keyboard trim to release it from the computer.
    • Work your way around the sides and bottom edge of the keyboard trim.
    • Lift up to remove the keyboard trim from the unit.
    FixBot'a Sor
    Yorum Ekle
  4. Dell Precision M4600 Memory Module Replacement, KeyBoard: adım 4, 3 resimden 1. Dell Precision M4600 Memory Module Replacement, KeyBoard: adım 4, 3 resimden 2. Dell Precision M4600 Memory Module Replacement, KeyBoard: adım 4, 3 resimden 3.
    • Remove the screws securing the keyboard in place.
    • Starting from the bottom of the keyboard, separate the keyboard from the system and turn the keyboard over.
    • Disconnect the keyboard data cable from the system board.
    FixBot'a Sor
    Yorum Ekle
  5. Dell Precision M4600 Memory Module Replacement: adım 5, 3 resimden 1. Dell Precision M4600 Memory Module Replacement: adım 5, 3 resimden 2. Dell Precision M4600 Memory Module Replacement: adım 5, 3 resimden 3.
    • Remove the keyboard.
    • Peel back the adhesive tape securing the keyboard data cable to the back of the keyboard.
    • Disconnect the keyboard data cable from the back of the keyboard.
    FixBot'a Sor
    Yorum Ekle
  6. Dell Precision M4600 Memory Module Replacement: adım 6, 1 resimden 1.
    • Peel the keyboard data cable away from the keyboard and remove.
    FixBot'a Sor
    Yorum Ekle
  7. Dell Precision M4600 Memory Module Replacement, Memory Module: adım 7, 2 resimden 1. Dell Precision M4600 Memory Module Replacement, Memory Module: adım 7, 2 resimden 2.
    • Flip the the Bottom
    • Gently pry the retention clips away from the memory modules.
    • Remove the memory modules from the computer.
    FixBot'a Sor
    Yorum Ekle
  8. Dell Precision M4600 Memory Module Replacement: adım 8, 2 resimden 1. Dell Precision M4600 Memory Module Replacement: adım 8, 2 resimden 2.
    • Flip to the Top.
    • Gently pry the retention clips away from the memory module.
    • Remove the memory module from the computer.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Johnathan Hammond
46.149 İtibar
408 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
45 Üyeler
2.003 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 38
Her zaman: 1,654
