Ana içeriğe geç
Dell Precision M4700 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Precision M4700 Hard Drive Replacement, Battery: adım 1, 2 resimden 1. Dell Precision M4700 Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Slide the release latch to unlock the battery.
    • Flip and remove the battery from the computer.
  2. Dell Precision M4700 Hard Drive Replacement, Base Cover: adım 2, 2 resimden 1. Dell Precision M4700 Hard Drive Replacement, Base Cover: adım 2, 2 resimden 2.
    • Remove the screws that secure the base cover to the computer. Press the rubber tabs towards the rear of the computer to disengage the base cover.
    • Flip and remove the base cover from the computer.
  3. Dell Precision M4700 Hard Drive Replacement, Hard Drive: adım 3, 1 resimden 1.
    • Remove the screws that secure the hard drive to the computer. Slide the hard -drive latch to the unlock position and pull out the hard drive from the computer.
  4. Dell Precision M4700 Hard Drive Replacement: adım 4, 1 resimden 1.
    • Flex the hard-drive bracket outward and pull out the hard drive from the bracket.
    • NOTE: A rubber filler is installed to the hard-drive bracket for 7 mm hard drives. It is designed to prevent vibrations and for correct installation of the 7 mm hard drives. 9 mm hard drives do not require the filler when installed into the hard-drive bracket.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Johnathan Hammond
45.237 İtibar
408 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
43 Üyeler
1.985 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 47
Her zaman: 5,213
