Ana içeriğe geç
Dell Precision M6400 Memory Module Replacement
Neye ihtiyacın var
  1. Dell Precision M6400 Memory Module Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the battery release latch and remove the battery.
    FixBot'a Sor
    Yorum Ekle
  2. Dell Precision M6400 Memory Module Replacement, Base Cover: adım 2, 1 resimden 1.
    • Remove the two M2 x 3-mm screws.
    • Slide the cover toward the front of the computer to release the tabs from the base assembly.
    • Remove the cover from the base assembly.
    FixBot'a Sor
    Yorum Ekle
  3. Dell Precision M6400 Memory Module Replacement, LED Cover: adım 3, 1 resimden 1.
    • Starting on the left, gently lift the LED cover and disconnect the power cable and the biometer cable if present.
    FixBot'a Sor
    Yorum Ekle
  4. Dell Precision M6400 Memory Module Replacement, KeyBoard: adım 4, 1 resimden 1.
    • Remove the four M2 x 3-mm screws along the top of the keyboard.
    • NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time- consuming to replace. Exercise care when removing and handling the keyboard.
    • Use the metal pull tabs to gently slide the keyboard toward the back of the computer to disconnect the keyboard.
    FixBot'a Sor
    Yorum Ekle
  5. Dell Precision M6400 Memory Module Replacement, Memory Module: adım 5, 1 resimden 1.
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
    • Remove the memory module from the connector.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Johnathan Hammond
46.149 İtibar
408 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
45 Üyeler
2.003 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 45
Her zaman: 1,716
