Ana içeriğe geç
Dell Precision T3400 Power Supply Replacement
Neye ihtiyacın var
  1. Dell Precision T3400 Power Supply Replacement, Disconnect the DC power cables from the system board and the drives.: adım 1, 1 resimden 1.
    • Pay special attention to where the DC power cables are plugged in so that they can be replaced the same way.
    • You may need to remove the heat-sink assembly in order to detach certain cables.
    FixBot'a Sor
    Yorum Ekle
  2. Dell Precision T3400 Power Supply Replacement, Remove the power supply from the computer case.: adım 2, 1 resimden 1.
    • Remove the four screws on the back of the power supply using a standard Phillips-head screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. Dell Precision T3400 Power Supply Replacement, Remove the power supply from the computer case.: adım 3, 1 resimden 1.
    • Press the secure tab down and slide the power supply out of its bracket to remove it.
    FixBot'a Sor
    Yorum Ekle
  4. Dell Precision T3400 Power Supply Replacement, Install the new power supply.: adım 4, 1 resimden 1.
    • Slide the power supply into the empty bracket. It will click into place.
    • Replace the four screws to secure the power supply to the computer case.
    FixBot'a Sor
    Yorum Ekle
  5. Dell Precision T3400 Power Supply Replacement, Reconnect the DC power cables.: adım 5, 1 resimden 1.
    • Remember to use the case's secure tabs to hold cables out of the way.
    • If you removed the heat-sink assembly in order to remove any power supply cables, be sure to re-install the assembly.
    FixBot'a Sor
    Yorum Ekle
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Josette Cormier
13 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-2, Gulbrandsen Fall 2013 UMass Dartmouth, Team 1-2, Gulbrandsen Fall 2013 üyesi
UMASSD-GULBRANDSEN-F13S1G2
3 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 45
Her zaman: 8,988
