Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
If your PC is on, shut it down by navigating to the window tab in the bottom left corner, selecting the power icon, and then selecting shut down.
Unplug the PC from the wall.
Disconnect the power cable from the tower, unplug keyboards, monitors, or any other devices, and remove any USB devices.
Lay the computer on its side so the panel faces up.
Push the cover release latch at the back of the computer's case. The cover should pop off and away from the computer.
Press down on both of the two secure tabs on each side of the RAM stick.
When you simultaneously press each of the secure tabs, the RAM stick will move up and out of its slot.
Align the notch on the bottom of the RAM stick with the notch in the slot.
Insert the RAM stick into the slot until the stick snaps into position. If you insert the stick correctly, the secure tabs will snap into the notches on each side.
5 farklı kişi bu kılavuzu tamamladı.
