Giriş
RAM stands for Random-Access-Memory. RAM is essentially a short-term memory that is used to store data for computer processors to receive instructions. Adding more RAM is the easiest way to boost the performance of your computer. Make sure to check the available RAM slots in your motherboard. Also, check the specification of the motherboard to find out the maximum RAM capacity that is supported by your motherboard.
Only ECC RAM is compatible with the DELL Precision T5600 workstation.
Before you begin, check your workstation's requirements to ensure that your replacement RAM is compatible with your workstation.
Lay the case on its side with the handle side pointing up. Remove the side panel of the computer case by pulling on the handle, as shown in this step.
