Ana içeriğe geç
Dell Streak 7 Battery Replacement
Neye ihtiyacın var
  1. Dell Streak 7 Battery Replacement, Front Panel Assembly: adım 1, 1 resimden 1.
    • Insert the spudger under the capacitive button panel, and slide the spudger all the way around.
    • You will want to heat up the screen edges with the iOpener to help facilitate removal.
    FixBot'a Sor
    Yorum Ekle
  2. Dell Streak 7 Battery Replacement: adım 2, 1 resimden 1.
    • Remove the button cover by lifting the cover away from the tablet.
    FixBot'a Sor
    Yorum Ekle
  3. Dell Streak 7 Battery Replacement: adım 3, 1 resimden 1.
    • Using the Torx screwdriver, remove the 4mm screws.
    FixBot'a Sor
    Yorum Ekle
  4. Dell Streak 7 Battery Replacement: adım 4, 1 resimden 1.
    • With the Torx screwdriver, remove the two 5mm screws.
    FixBot'a Sor
    Yorum Ekle
  5. Dell Streak 7 Battery Replacement: adım 5, 2 resimden 1. Dell Streak 7 Battery Replacement: adım 5, 2 resimden 2.
    • Using the spudger, insert it under the black side panel. Slide the spudger all the way around until the cover piece comes off.
    • With the Torx screwdriver, remove the two 4mm screws.
    FixBot'a Sor
    Yorum Ekle
  6. Dell Streak 7 Battery Replacement: adım 6, 1 resimden 1.
    • Use the spudger to go along the edges of the device and pop out the latches securing the display to the case.
    FixBot'a Sor
    Yorum Ekle
  7. Dell Streak 7 Battery Replacement: adım 7, 2 resimden 1. Dell Streak 7 Battery Replacement: adım 7, 2 resimden 2.
    • Ribbon cables are very sensitive and prone to breaking
    • Disconnect the ribbon cables by unlocking the connector and pulling the cable out slowly.
    • Make sure all the cables are unplugged before opening the device completely. Failure to do so might lead to broken or torn cables.
    FixBot'a Sor
    Yorum Ekle
  8. Dell Streak 7 Battery Replacement, Headphone Jack: adım 8, 1 resimden 1.
    • Using the spudger, disconnect the ribbon cable by lifting up on the connector.
    • Ribbon cables are fragile and easily broken.
    FixBot'a Sor
    Yorum Ekle
  9. Dell Streak 7 Battery Replacement: adım 9, 2 resimden 1. Dell Streak 7 Battery Replacement: adım 9, 2 resimden 2.
    • Pull the headphone jack up, away from the case.
    FixBot'a Sor
    Yorum Ekle
  10. Dell Streak 7 Battery Replacement, GSM Module: adım 10, 2 resimden 1. Dell Streak 7 Battery Replacement, GSM Module: adım 10, 2 resimden 2.
    • With the spudger, disconnect the antenna cable located on the module.
    FixBot'a Sor
    Yorum Ekle
  11. Dell Streak 7 Battery Replacement: adım 11, 2 resimden 1. Dell Streak 7 Battery Replacement: adım 11, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using tweezers, remove the tape connected to the GSM module.
    FixBot'a Sor
    Yorum Ekle
  12. Dell Streak 7 Battery Replacement: adım 12, 2 resimden 1. Dell Streak 7 Battery Replacement: adım 12, 2 resimden 2.
    • Remove the two 3mm screws securing the GSM module. Use the Torx screwdriver.
    FixBot'a Sor
    Yorum Ekle
  13. Dell Streak 7 Battery Replacement: adım 13, 1 resimden 1.
    • Disconnect the GSM module by lifting the module up, out of the case.
    FixBot'a Sor
    Yorum Ekle
  14. Dell Streak 7 Battery Replacement, Motherboard: adım 14, 3 resimden 1. Dell Streak 7 Battery Replacement, Motherboard: adım 14, 3 resimden 2. Dell Streak 7 Battery Replacement, Motherboard: adım 14, 3 resimden 3.
    • Using the spudger, disconnect the front camera by lifting up on the connector.
    FixBot'a Sor
    Yorum Ekle
  15. Dell Streak 7 Battery Replacement: adım 15, 1 resimden 1.
    • Using the Torx screwdriver, remove the six 3mm screws .
    FixBot'a Sor
    Yorum Ekle
  16. Dell Streak 7 Battery Replacement: adım 16, 2 resimden 1. Dell Streak 7 Battery Replacement: adım 16, 2 resimden 2.
    • Lift up the metal cover.
    FixBot'a Sor
    Yorum Ekle
  17. Dell Streak 7 Battery Replacement: adım 17, 1 resimden 1.
    • Use the spudger to lift the vibration motor out of the case.
    FixBot'a Sor
    Yorum Ekle
  18. Dell Streak 7 Battery Replacement: adım 18, 1 resimden 1.
    • Pull out the motherboard and the battery.
    FixBot'a Sor
    Yorum Ekle
  19. Dell Streak 7 Battery Replacement, Battery: adım 19, 2 resimden 1. Dell Streak 7 Battery Replacement, Battery: adım 19, 2 resimden 2.
    • Use the spudger to lift up and detach the cable connecting the battery to the motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Jair Garcia Varela
337 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-6, Passmore Fall 2016 USF Tampa, Team 4-6, Passmore Fall 2016 üyesi
USFT-PASSMORE-F16S4G6
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 23
Her zaman: 1,512
