Ana içeriğe geç
Dell Streak 7 Headphone Jack Replacement
Neye ihtiyacın var
  1. Dell Streak 7 Headphone Jack Replacement, Front Panel Assembly: adım 1, 1 resimden 1.
    • Insert the spudger under the capacitive button panel, and slide the spudger all the way around.
    • You will want to heat up the screen edges with the iOpener to help facilitate removal.
  2. Dell Streak 7 Headphone Jack Replacement: adım 2, 1 resimden 1.
    • Remove the button cover by lifting the cover away from the tablet.
  3. Dell Streak 7 Headphone Jack Replacement: adım 3, 1 resimden 1.
    • Using the Torx screwdriver, remove the 4mm screws.
  4. Dell Streak 7 Headphone Jack Replacement: adım 4, 1 resimden 1.
    • With the Torx screwdriver, remove the two 5mm screws.
  5. Dell Streak 7 Headphone Jack Replacement: adım 5, 2 resimden 1. Dell Streak 7 Headphone Jack Replacement: adım 5, 2 resimden 2.
    • Using the spudger, insert it under the black side panel. Slide the spudger all the way around until the cover piece comes off.
    • With the Torx screwdriver, remove the two 4mm screws.
  6. Dell Streak 7 Headphone Jack Replacement: adım 6, 1 resimden 1.
    • Use the spudger to go along the edges of the device and pop out the latches securing the display to the case.
  7. Dell Streak 7 Headphone Jack Replacement: adım 7, 2 resimden 1. Dell Streak 7 Headphone Jack Replacement: adım 7, 2 resimden 2.
    • Ribbon cables are very sensitive and prone to breaking
    • Disconnect the ribbon cables by unlocking the connector and pulling the cable out slowly.
    • Make sure all the cables are unplugged before opening the device completely. Failure to do so might lead to broken or torn cables.
  8. Dell Streak 7 Headphone Jack Replacement, Headphone Jack: adım 8, 1 resimden 1.
    • Using the spudger, disconnect the ribbon cable by lifting up on the connector.
    • Ribbon cables are fragile and easily broken.
  9. Dell Streak 7 Headphone Jack Replacement: adım 9, 2 resimden 1. Dell Streak 7 Headphone Jack Replacement: adım 9, 2 resimden 2.
    • Pull the headphone jack up, away from the case.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ali Benjelloun
376 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-6, Passmore Fall 2016 USF Tampa, Team 4-6, Passmore Fall 2016 üyesi
USFT-PASSMORE-F16S4G6
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 7
Her zaman: 154
