Giriş
Use this guide to replace the headphone jack on your Dell Streak 7. This guide will show you how to remove the old headphone jack.
Neye ihtiyacın var
Insert the spudger under the capacitive button panel, and slide the spudger all the way around.
Using the spudger, disconnect the ribbon cable by lifting up on the connector.
Bir başkası bu kılavuzu tamamladı.
