Ana içeriğe geç
Dell Studio 1535 Memory (RAM) Replacement
Neye ihtiyacın var
  1. Dell Studio 1535 Memory (RAM) Replacement, Memory (RAM): adım 1, 3 resimden 1. Dell Studio 1535 Memory (RAM) Replacement, Memory (RAM): adım 1, 3 resimden 2. Dell Studio 1535 Memory (RAM) Replacement, Memory (RAM): adım 1, 3 resimden 3.
    • Gather materials and supplies
    • Flip laptop over
    • Remove battery as a safety precaution
    FixBot'a Sor
    Yorum Ekle
  2. Dell Studio 1535 Memory (RAM) Replacement: adım 2, 3 resimden 1. Dell Studio 1535 Memory (RAM) Replacement: adım 2, 3 resimden 2. Dell Studio 1535 Memory (RAM) Replacement: adım 2, 3 resimden 3.
    • Unscrew the screws holding the panel on the underside of the laptop
    • Remove the panel on the bottom of the laptop
    • The screws will loosen but they will not come out, this is normal
    • Sometimes a flat object like a flathead screwdriver is necessary to remove the panel
    • Set the panel aside
    FixBot'a Sor
    Yorum Ekle
  3. Dell Studio 1535 Memory (RAM) Replacement: adım 3, 1 resimden 1.
    • Locate the memory. It should be very easy to find. It will be on the right side of the hard drive, and will look like the picture (Depending on the type of memory your system came with, it may be a different color or style)
    FixBot'a Sor
    Yorum Ekle
  4. Dell Studio 1535 Memory (RAM) Replacement: adım 4, 3 resimden 1. Dell Studio 1535 Memory (RAM) Replacement: adım 4, 3 resimden 2. Dell Studio 1535 Memory (RAM) Replacement: adım 4, 3 resimden 3.
    • Now we'll remove one stick of memory; we'll start with the one on the top (assuming the battery is further away from you)
    • On each side of the stick you will see two metal tabs
    • Press these tabs outwards in order to release the RAM
    • Press these tabs gently. I haven't broken one, but they do look very weak
    • The slot is spring loaded, and once the tabs are properly opened, it should spring up at an angle
    FixBot'a Sor
    Yorum Ekle
  5. Dell Studio 1535 Memory (RAM) Replacement: adım 5, 3 resimden 1. Dell Studio 1535 Memory (RAM) Replacement: adım 5, 3 resimden 2. Dell Studio 1535 Memory (RAM) Replacement: adım 5, 3 resimden 3.
    • In order to actually remove the stick, simply pull it outwards of the slot
    • It may be in a bit tight, wiggling it out is helpful
    • Once it's out, put it off to the side. Remember which slot it was in; placing it off to the side in the same position is helpful
    FixBot'a Sor
    Yorum Ekle
  6. Dell Studio 1535 Memory (RAM) Replacement: adım 6, 3 resimden 1. Dell Studio 1535 Memory (RAM) Replacement: adım 6, 3 resimden 2. Dell Studio 1535 Memory (RAM) Replacement: adım 6, 3 resimden 3.
    • The same process is repeated for the second stick of RAM
    • This time it will spring up the opposite direction
    • Place it off to the side as well, remembering which slot it was in
    FixBot'a Sor
    Yorum Ekle
  7. Dell Studio 1535 Memory (RAM) Replacement: adım 7, 2 resimden 1. Dell Studio 1535 Memory (RAM) Replacement: adım 7, 2 resimden 2.
    • Now the memory has been successfully removed
    • Remembering which slot the RAM was in saves time and effort
    • Each stick has a grove where the pins are, and the slot has a corresponding notch in it
    • Remembering which one goes where saves you time when re-installing the memory
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Eric Bentley
1.350 İtibar
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 36
Her zaman: 7,622
