Ana içeriğe geç
Dell Studio 1555 Display Replacement
Neye ihtiyacın var
  1. Dell Studio 1555 Display Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off and unplug the laptop.
    • Failure to properly turn off device before handling the battery could result in electrical shock.
    • Flip the laptop so the underside is facing up with the battery closest to you.
    FixBot'a Sor
    Yorum Ekle
  2. Dell Studio 1555 Display Replacement: adım 2, 3 resimden 1. Dell Studio 1555 Display Replacement: adım 2, 3 resimden 2. Dell Studio 1555 Display Replacement: adım 2, 3 resimden 3.
    • Slide the locking switch to the left to release the battery.
    FixBot'a Sor
    Yorum Ekle
  3. Dell Studio 1555 Display Replacement: adım 3, 1 resimden 1.
    • Gently pull the battery away from the device.
    FixBot'a Sor
    Yorum Ekle
  4. Dell Studio 1555 Display Replacement, Display: adım 4, 2 resimden 1. Dell Studio 1555 Display Replacement, Display: adım 4, 2 resimden 2.
    • Insert a plastic opening tool between the bezel and the display cover.
    • Wiggle it to the release the latches.
    • Separate the bezel from the cover.
    FixBot'a Sor
    Yorum Ekle
  5. Dell Studio 1555 Display Replacement: adım 5, 2 resimden 1. Dell Studio 1555 Display Replacement: adım 5, 2 resimden 2.
    • Remove the four 3 mm screws securing the LCD using the #1 Phillips screwdriver.
    FixBot'a Sor
    Yorum Ekle
  6. Dell Studio 1555 Display Replacement: adım 6, 1 resimden 1.
    • Separate the LCD assembly from the display cover so you will be able to access the webcam cable.
    • Unplug the camera cable.
    FixBot'a Sor
    Yorum Ekle
  7. Dell Studio 1555 Display Replacement: adım 7, 2 resimden 1. Dell Studio 1555 Display Replacement: adım 7, 2 resimden 2.
    • Place the LCD face down on the top cover.
    • Remove the sticky tape securing the video cable connector.
    • Unplug the video cable from the screen.
    FixBot'a Sor
    Yorum Ekle
  8. Dell Studio 1555 Display Replacement: adım 8, 3 resimden 1. Dell Studio 1555 Display Replacement: adım 8, 3 resimden 2. Dell Studio 1555 Display Replacement: adım 8, 3 resimden 3.
    • Remove the LCD from the laptop.
    • Remove the four 3mm screws holding the mounting brackets using the #1 Phillips screwdriver. Two on each side.
    • You will have to transfer the mounting brackets to the new screen.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Josh Boone
586 İtibar
4 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 29
Her zaman: 1,915
