Ana içeriğe geç
Dell Studio 1555 Keyboard Replacement
Neye ihtiyacın var
  1. Dell Studio 1555 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off and unplug the laptop.
    • Failure to properly turn off device before handling the battery could result in electrical shock.
    • Flip the laptop so the underside is facing up with the battery closest to you.
  2. Dell Studio 1555 Keyboard Replacement: adım 2, 3 resimden 1. Dell Studio 1555 Keyboard Replacement: adım 2, 3 resimden 2. Dell Studio 1555 Keyboard Replacement: adım 2, 3 resimden 3.
    • Slide the locking switch to the left to release the battery.
  3. Dell Studio 1555 Keyboard Replacement: adım 3, 1 resimden 1.
    • Gently pull the battery away from the device.
  4. Dell Studio 1555 Keyboard Replacement, Keyboard: adım 4, 1 resimden 1.
    • Remove the single 3mm screw underneath the battery with a #1 Phillips screw driver, which holds the media control cover.
  5. Dell Studio 1555 Keyboard Replacement: adım 5, 2 resimden 1. Dell Studio 1555 Keyboard Replacement: adım 5, 2 resimden 2.
    • Flip the laptop over and flatten it out as much as possible.
    • Unsnap the media control cover from the laptop starting nearest to the display.
  6. Dell Studio 1555 Keyboard Replacement: adım 6, 2 resimden 1. Dell Studio 1555 Keyboard Replacement: adım 6, 2 resimden 2.
    • Remove the two 3mm screws with a #1 Phillips screwdriver, holding down the keyboard.
  7. Dell Studio 1555 Keyboard Replacement: adım 7, 1 resimden 1.
    • Slowly lift the keyboard away from the base.
    • If you pull to hard you risk breaking the keyboard cable connector from the motherboard.
  8. Dell Studio 1555 Keyboard Replacement: adım 8, 3 resimden 1. Dell Studio 1555 Keyboard Replacement: adım 8, 3 resimden 2. Dell Studio 1555 Keyboard Replacement: adım 8, 3 resimden 3.
    • Flip up the black tab on the keyboard ZIF connector and unplug the cable.
  9. Dell Studio 1555 Keyboard Replacement: adım 9, 1 resimden 1.
    • Remove the keyboard
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Hunter Tuck
214 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 926
