Giriş
The memory of your laptop may become corrupted or full and need to be replaced. A Philips 1 screwdriver is required for this guide.
Neye ihtiyacın var
Turn off and unplug the laptop.
Flip the laptop so the underside is facing up with the battery closest to you.
Loosen the three 5mm screws from the back panel using the # 1 Philips screwdriver.
Press the tabs outwards to release the tabs. The memory stick is spring loaded and will be released at an angle.
3 farklı kişi bu kılavuzu tamamladı.
