Ana içeriğe geç
Dell Studio 1737 Keyboard Replacement
Neye ihtiyacın var
  1. Dell Studio 1737 Keyboard Replacement, Battery: adım 1, 2 resimden 1. Dell Studio 1737 Keyboard Replacement, Battery: adım 1, 2 resimden 2.
    • Slide the battery release slider all the way to the right and push the battery straight out of the back of the computer
  2. Dell Studio 1737 Keyboard Replacement, Keyboard: adım 2, 1 resimden 1.
    • Use a plastic opening tool to detach the internal clips (marked with red boxes in photo) and release the small plastic panel above the keyboard
    • This panel doesn't come off just yet, this step is just to make it easier when it comes time to remove it
  3. Dell Studio 1737 Keyboard Replacement: adım 3, 1 resimden 1.
    • Remove the 4mm ph1 screw under the battery
  4. Dell Studio 1737 Keyboard Replacement: adım 4, 3 resimden 1. Dell Studio 1737 Keyboard Replacement: adım 4, 3 resimden 2. Dell Studio 1737 Keyboard Replacement: adım 4, 3 resimden 3.
    • Pry black panel away from laptop body starting at the base of the screen
    • Be careful when flipping the panel over, as the panel is still attached by the fragile ribbon cable
    • Flip the panel over onto the keyboard
    • Detach the ribbon cable from the motherboard as shown
  5. Dell Studio 1737 Keyboard Replacement: adım 5, 1 resimden 1.
    • Starting at the top where you just removed the black panel, pry the black bezel away from the outside of the keyboard
  6. Dell Studio 1737 Keyboard Replacement: adım 6, 2 resimden 1. Dell Studio 1737 Keyboard Replacement: adım 6, 2 resimden 2.
    • Use a small screwdriver to take out the 4 4mm ph1 screws along the top of the keyboard
    • Lift from the top of the keyboard and flip it over onto the palmrest
    • Again, be very careful of the ribbon cable attaching it, as these are easily damaged
  7. Dell Studio 1737 Keyboard Replacement: adım 7, 2 resimden 1. Dell Studio 1737 Keyboard Replacement: adım 7, 2 resimden 2.
    • Remove the ribbon cable as shown
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Joseph Jacavone
785 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S8-G4, Catania Spring 2017 UMass Dartmouth, Team S8-G4, Catania Spring 2017 üyesi
UMASSD-CATANIA-S17S8G4
3 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 11
Her zaman: 754
