Ana içeriğe geç
Dell VRP100 Camera Replacement
Neye ihtiyacın var
  1. Dell VRP100 Camera Replacement, Cover Panel: adım 1, 3 resimden 1. Dell VRP100 Camera Replacement, Cover Panel: adım 1, 3 resimden 2. Dell VRP100 Camera Replacement, Cover Panel: adım 1, 3 resimden 3.
    • Remove the black foam padding by peeling away slowly.
    • Remove the front and back padding from the headset by peeling away slowly.
  2. Dell VRP100 Camera Replacement: adım 2, 1 resimden 1.
    • Remove the six 5.5mm PH000 screws from the cover by rotating counter-clockwise.
    • Cover panel may need to be pushed in before inserting screws.
  3. Dell VRP100 Camera Replacement: adım 3, 3 resimden 1. Dell VRP100 Camera Replacement: adım 3, 3 resimden 2. Dell VRP100 Camera Replacement: adım 3, 3 resimden 3.
    • Remove the cover using one of the plastic opening tools, and then carefully pull it from the casing.
  4. Dell VRP100 Camera Replacement: adım 4, 3 resimden 1. Dell VRP100 Camera Replacement: adım 4, 3 resimden 2. Dell VRP100 Camera Replacement: adım 4, 3 resimden 3.
    • Carefully remove the lens and motherboard assembly from the white casing.
  5. Dell VRP100 Camera Replacement, Camera: adım 5, 3 resimden 1. Dell VRP100 Camera Replacement, Camera: adım 5, 3 resimden 2. Dell VRP100 Camera Replacement, Camera: adım 5, 3 resimden 3.
    • Remove the four 2.5mm PH000 screws by rotating counter-clockwise.
    • Separate the lens housing from the motherboard panel.
  6. Dell VRP100 Camera Replacement: adım 6, 2 resimden 1. Dell VRP100 Camera Replacement: adım 6, 2 resimden 2.
    • Remove the two 2.5mm PH000 screws from the motherboard by rotating counter-clockwise.
    • Remove the four 3.9mm PH000 screws from the white casing by rotating counter-clockwise.
  7. Dell VRP100 Camera Replacement: adım 7, 2 resimden 1. Dell VRP100 Camera Replacement: adım 7, 2 resimden 2.
    • Remove the flat-topped connector by lifting it straight up from the motherboard.
    • Carefully remove the camera from the casing with the blunt nose tweezers by holding onto the copper tape.
    • To reinstall, line up the connectors and firmly push until you hear a pop.
Sonuç
Lauren Monzon
217 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G1, White Fall 2018 Cal Poly, Team S17-G1, White Fall 2018 üyesi
CPSU-WHITE-F18S17G1
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 365
