Ana içeriğe geç
Dell VRP100 HDMI/USB Cable Replacement
Neye ihtiyacın var
  1. Dell VRP100 HDMI/USB Cable Replacement, Cover Panel: adım 1, 3 resimden 1. Dell VRP100 HDMI/USB Cable Replacement, Cover Panel: adım 1, 3 resimden 2. Dell VRP100 HDMI/USB Cable Replacement, Cover Panel: adım 1, 3 resimden 3.
    • Remove the black foam padding by peeling away slowly.
    • Remove the front and back padding from the headset by peeling away slowly.
    FixBot'a Sor
    Yorum Ekle
  2. Dell VRP100 HDMI/USB Cable Replacement: adım 2, 1 resimden 1.
    • Remove the six 5.5mm PH000 screws from the cover by rotating counter-clockwise.
    • Cover panel may need to be pushed in before inserting screws.
    FixBot'a Sor
    Yorum Ekle
  3. Dell VRP100 HDMI/USB Cable Replacement: adım 3, 3 resimden 1. Dell VRP100 HDMI/USB Cable Replacement: adım 3, 3 resimden 2. Dell VRP100 HDMI/USB Cable Replacement: adım 3, 3 resimden 3.
    • Remove the cover using one of the plastic opening tools, and then carefully pull it from the casing.
    FixBot'a Sor
    Yorum Ekle
  4. Dell VRP100 HDMI/USB Cable Replacement: adım 4, 3 resimden 1. Dell VRP100 HDMI/USB Cable Replacement: adım 4, 3 resimden 2. Dell VRP100 HDMI/USB Cable Replacement: adım 4, 3 resimden 3.
    • Carefully remove the lens and motherboard assembly from the white casing.
    FixBot'a Sor
    Yorum Ekle
  5. Dell VRP100 HDMI/USB Cable Replacement, HDMI/USB Cable: adım 5, 2 resimden 1. Dell VRP100 HDMI/USB Cable Replacement, HDMI/USB Cable: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Remove the two 3.4mm PH000 screws from the cover by rotating counter-clockwise.
    • Peel off the tape using your hands or the blunt nose tweezers.
    FixBot'a Sor
    Yorum Ekle
  6. Dell VRP100 HDMI/USB Cable Replacement: adım 6, 3 resimden 1. Dell VRP100 HDMI/USB Cable Replacement: adım 6, 3 resimden 2. Dell VRP100 HDMI/USB Cable Replacement: adım 6, 3 resimden 3.
    • Remove the two 5.5mm PH000 screws from the cover by rotating counter-clockwise.
    • Hold the HDMI/USB cable and remove from the connection.
    FixBot'a Sor
    Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Marco Salazar
381 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G1, White Fall 2018 Cal Poly, Team S17-G1, White Fall 2018 üyesi
CPSU-WHITE-F18S17G1
4 Üyeler
12 adet Kılavuz yazıldı
6Kılavuz Yorumları
Hi
Nice breakdown. Would you know where I can purchase a spare cable (I’m in the UK) as I can find nothing online regarding where to buy one.
Thanks
Jason
jason.d.spiller - Yanıt Paylaş
Me too, looking for a cable replacement.
Filipi Nascimento Silva - Yanıt Paylaş
also looking for replacement cable as mine has twisted up so bad that there is no longer and picture coming through when can i buy the replacement
Tom Powell - Yanıt Paylaş
I am also looking for a replacement cable. Could it be soldered on from another cable?
Peter Hindes - Yanıt Paylaş
Me too for replacement cable specs please
geebee800 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 46
Her zaman: 2,049
