Giriş
This replacement guide will show you how to replace the HDMI/USB cable on your Dell VRP100 headset. With the right tools, this will be a quick and easy replacement.
Neye ihtiyacın var
Remove the black foam padding by peeling away slowly.
Remove the front and back padding from the headset by peeling away slowly.
Remove the cover using one of the plastic opening tools, and then carefully pull it from the casing.
Remove the six 5.5mm PH000 screws from the cover by rotating counter-clockwise.
Carefully remove the lens and motherboard assembly from the white casing.
add ‘How’ to second bullet point.
The “carefully” part should be moved so that the sentence starts with a verb
Remove the two 3.4mm PH000 screws from the cover by rotating counter-clockwise.
Peel off the tape using your hands or the blunt nose tweezers.
5 farklı kişi bu kılavuzu tamamladı.
6 Yorum
Hi
Nice breakdown. Would you know where I can purchase a spare cable (I’m in the UK) as I can find nothing online regarding where to buy one.
Thanks
Jason
Me too, looking for a cable replacement.
also looking for replacement cable as mine has twisted up so bad that there is no longer and picture coming through when can i buy the replacement
I am also looking for a replacement cable. Could it be soldered on from another cable?
Parallel structure
Andres Ikaika Elzaurdia - Yanıt
