Ana içeriğe geç
Dell VRP100 Lens Replacement
Neye ihtiyacın var
  1. Dell VRP100 Lens Replacement, Cover Panel: adım 1, 3 resimden 1. Dell VRP100 Lens Replacement, Cover Panel: adım 1, 3 resimden 2. Dell VRP100 Lens Replacement, Cover Panel: adım 1, 3 resimden 3.
    • Remove the black foam padding by peeling away slowly.
    • Remove the front and back padding from the headset by peeling away slowly.
    FixBot'a Sor
    Yorum Ekle
  2. Dell VRP100 Lens Replacement: adım 2, 1 resimden 1.
    • Remove the six 5.5mm PH000 screws from the cover by rotating counter-clockwise.
    • Cover panel may need to be pushed in before inserting screws.
    FixBot'a Sor
    Yorum Ekle
  3. Dell VRP100 Lens Replacement: adım 3, 3 resimden 1. Dell VRP100 Lens Replacement: adım 3, 3 resimden 2. Dell VRP100 Lens Replacement: adım 3, 3 resimden 3.
    • Remove the cover using one of the plastic opening tools, and then carefully pull it from the casing.
    FixBot'a Sor
    Yorum Ekle
  4. Dell VRP100 Lens Replacement: adım 4, 3 resimden 1. Dell VRP100 Lens Replacement: adım 4, 3 resimden 2. Dell VRP100 Lens Replacement: adım 4, 3 resimden 3.
    • Carefully remove the lens and motherboard assembly from the white casing.
    FixBot'a Sor
    Yorum Ekle
  5. Dell VRP100 Lens Replacement, Lens: adım 5, 2 resimden 1. Dell VRP100 Lens Replacement, Lens: adım 5, 2 resimden 2.
    • Deattach the black cover from the lens with a metal spudger.
    • This will “click” back into place during replacement.
    FixBot'a Sor
    Yorum Ekle
  6. Dell VRP100 Lens Replacement: adım 6, 3 resimden 1. Dell VRP100 Lens Replacement: adım 6, 3 resimden 2. Dell VRP100 Lens Replacement: adım 6, 3 resimden 3.
    • Gently insert the metal spudger between the lens and the lens casing.
    • Rotate the spudger around the exterior of the lens and lens housing, separating them.
    • The lens is held in place with an adhesive that will have to be applied during reassembly.
    FixBot'a Sor
    Yorum Ekle
  7. Dell VRP100 Lens Replacement: adım 7, 1 resimden 1.
    • Holding the lens around the outside, gently lift it out of its housing.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Chris Grabow
285 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G1, White Fall 2018 Cal Poly, Team S17-G1, White Fall 2018 üyesi
CPSU-WHITE-F18S17G1
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 32
Her zaman: 1,224
