Giriş
If your Dell VRP100 headset has a cracked, scratched or broken lens you are definitely going to want to replace it. This guide has all the steps for you need replace those beat up lenses with new ones. You will need a metal spudger for parts of this guide.
Neye ihtiyacın var
Remove the black foam padding by peeling away slowly.
Remove the front and back padding from the headset by peeling away slowly.
Bir başkası bu kılavuzu tamamladı.
