Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove the black foam padding by peeling away slowly.
Remove the front and back padding from the headset by peeling away slowly.
Remove the six 5.5mm PH000 screws from the cover by rotating counter-clockwise.
Remove the cover using one of the plastic opening tools, and then carefully pull it from the casing.
Carefully remove the lens and motherboard assembly from the white casing.
Deattach the black cover from the lens with a metal spudger.
Gently insert the metal spudger between the lens and the lens casing.
Rotate the spudger around the exterior of the lens and lens housing, separating them.
Holding the lens around the outside, gently lift it out of its housing.
Bir başkası bu kılavuzu tamamladı.
