Ana içeriğe geç
Dell VRP100 Screen Replacement
Neye ihtiyacın var
  1. Dell VRP100 Screen Replacement, Cover Panel: adım 1, 3 resimden 1. Dell VRP100 Screen Replacement, Cover Panel: adım 1, 3 resimden 2. Dell VRP100 Screen Replacement, Cover Panel: adım 1, 3 resimden 3.
    • Remove the black foam padding by peeling away slowly.
    • Remove the front and back padding from the headset by peeling away slowly.
    FixBot'a Sor
    Yorum Ekle
  2. Dell VRP100 Screen Replacement: adım 2, 1 resimden 1.
    • Remove the six 5.5mm PH000 screws from the cover by rotating counter-clockwise.
    • Cover panel may need to be pushed in before inserting screws.
    FixBot'a Sor
    Yorum Ekle
  3. Dell VRP100 Screen Replacement: adım 3, 3 resimden 1. Dell VRP100 Screen Replacement: adım 3, 3 resimden 2. Dell VRP100 Screen Replacement: adım 3, 3 resimden 3.
    • Remove the cover using one of the plastic opening tools, and then carefully pull it from the casing.
    FixBot'a Sor
    Yorum Ekle
  4. Dell VRP100 Screen Replacement: adım 4, 3 resimden 1. Dell VRP100 Screen Replacement: adım 4, 3 resimden 2. Dell VRP100 Screen Replacement: adım 4, 3 resimden 3.
    • Carefully remove the lens and motherboard assembly from the white casing.
    FixBot'a Sor
    Yorum Ekle
  5. Dell VRP100 Screen Replacement, Screen: adım 5, 3 resimden 1. Dell VRP100 Screen Replacement, Screen: adım 5, 3 resimden 2. Dell VRP100 Screen Replacement, Screen: adım 5, 3 resimden 3.
    • Remove the four 2.5 mm PH000 screws by rotating counter-clockwise.
    • Separate the lenses from the motherboard panel.
    FixBot'a Sor
    Yorum Ekle
  6. Dell VRP100 Screen Replacement: adım 6, 2 resimden 1. Dell VRP100 Screen Replacement: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Take off the tape using the blunt nosed tweezers to disconnect the flat-topped connector from the motherboard.
    • The screen is attached to the motherboard using an adhesive.
    FixBot'a Sor
    Yorum Ekle
  7. Dell VRP100 Screen Replacement: adım 7, 3 resimden 1. Dell VRP100 Screen Replacement: adım 7, 3 resimden 2. Dell VRP100 Screen Replacement: adım 7, 3 resimden 3.
    • Lift the yellow tape with tweezers.
    • Remove the ribbon cable from the screen to the motherboard with tweezers.
    FixBot'a Sor
    Yorum Ekle
  8. Dell VRP100 Screen Replacement: adım 8, 3 resimden 1. Dell VRP100 Screen Replacement: adım 8, 3 resimden 2. Dell VRP100 Screen Replacement: adım 8, 3 resimden 3.
    • Remove the six 3.4mm PH000 screws by rotating counter-clockwise connecting the back panel to the screen.
    • Remove the back panel from the screen by carefully pulling apart the two.
    FixBot'a Sor
    Yorum Ekle
  9. Dell VRP100 Screen Replacement: adım 9, 3 resimden 1. Dell VRP100 Screen Replacement: adım 9, 3 resimden 2. Dell VRP100 Screen Replacement: adım 9, 3 resimden 3.
    • Peel away the screen with both hands.
    • A plastic opening tool may be required for removing the screen.
    • Adhesive may need to be reapplied during the rebuild.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Lauren Monzon
235 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G1, White Fall 2018 Cal Poly, Team S17-G1, White Fall 2018 üyesi
CPSU-WHITE-F18S17G1
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 32
Her zaman: 1,332
