Giriş
If you typically find yourself using the HDMI cable with your Dell Venue 11 Pro, then the mini HDMI port on your device might wear out sooner than you think. Fortunately, we've made a relatively easy guide you can follow to replace your mini HDMI board. You will need to complete the Battery and Frame replacement guides before proceeding to the Mini HDMI Port.
Neye ihtiyacın var
Turn your device over to the backside. On the notch at the bottom portion of the tablet, use your fingers to lift up the back cover.
Use your Philips #000 screwdriver to unscrew the fourteen 2.5 mm screws marked on the tablet.
To disconnect the left ribbon cable from the motherboard, place the flat end of your spudger under the edge of the pop connector and pry the connector straight up.
The right ribbon cable has a ZIF connector. Use the flat end of your spudger to lift up the small locking flap, then pull out the cable.
Identify the location of the HDMI Port, which will be in the left bottom part of the tablet.
Bir başkası bu kılavuzu tamamladı.
