Giriş
This guide will teach you how to replace your speakers. You will need to complete the battery and frame replacement guides before proceeding to the speakers.
Neye ihtiyacın var
Turn your device over to the backside. On the notch at the bottom portion of the tablet, use your fingers to lift up the back cover.
Use your Philips #000 screwdriver to unscrew the fourteen 2.5 mm screws marked on the tablet.
To disconnect the left ribbon cable from the motherboard, place the flat end of your spudger under the edge of the pop connector and pry the connector straight up.
The right ribbon cable has a ZIF connector. Use the flat end of your spudger to lift up the small locking flap, then pull out the cable.
Locate the right and left speakers to be replaced. For this guide, we will start with the left speaker, then the right speaker.
Bir başkası bu kılavuzu tamamladı.
