Ana içeriğe geç
Dell Venue 11 Pro Speakers Replacement
Neye ihtiyacın var
  1. Dell Venue 11 Pro Speakers Replacement, Battery: adım 1, 3 resimden 1. Dell Venue 11 Pro Speakers Replacement, Battery: adım 1, 3 resimden 2. Dell Venue 11 Pro Speakers Replacement, Battery: adım 1, 3 resimden 3.
    • Turn your device over to the backside. On the notch at the bottom portion of the tablet, use your fingers to lift up the back cover.
  2. Dell Venue 11 Pro Speakers Replacement: adım 2, 3 resimden 1. Dell Venue 11 Pro Speakers Replacement: adım 2, 3 resimden 2. Dell Venue 11 Pro Speakers Replacement: adım 2, 3 resimden 3.
    • Below the battery pack, there are two lock mechanisms. Push EACH lock to the LEFT until it makes a click noise. Lift the battery from the bottom up and remove.
  3. Dell Venue 11 Pro Speakers Replacement, Frame: adım 3, 2 resimden 1. Dell Venue 11 Pro Speakers Replacement, Frame: adım 3, 2 resimden 2.
    • Use your Philips #000 screwdriver to unscrew the fourteen 2.5 mm screws marked on the tablet.
    • These screws are extremely small. Place the screws aside in a container or on your magnetic mat to prevent accidental loss.
  4. Dell Venue 11 Pro Speakers Replacement: adım 4, 3 resimden 1. Dell Venue 11 Pro Speakers Replacement: adım 4, 3 resimden 2. Dell Venue 11 Pro Speakers Replacement: adım 4, 3 resimden 3.
    • Slide the cover on the two middle ribbon cables out to remove it. It should uncover the orange cable connectors.
  5. Dell Venue 11 Pro Speakers Replacement: adım 5, 3 resimden 1. Dell Venue 11 Pro Speakers Replacement: adım 5, 3 resimden 2. Dell Venue 11 Pro Speakers Replacement: adım 5, 3 resimden 3.
    • To disconnect the left ribbon cable from the motherboard, place the flat end of your spudger under the edge of the pop connector and pry the connector straight up.
    • The two ribbon cables connect the keyboard attachment ports to the motherboard. Damage to either cables can induce problems with the Dell mobile keyboard.
  6. Dell Venue 11 Pro Speakers Replacement: adım 6, 3 resimden 1. Dell Venue 11 Pro Speakers Replacement: adım 6, 3 resimden 2. Dell Venue 11 Pro Speakers Replacement: adım 6, 3 resimden 3.
    • The right ribbon cable has a ZIF connector. Use the flat end of your spudger to lift up the small locking flap, then pull out the cable.
    • Pulling the ribbon cable out before unlocking the connector can potentially damage the cable.
  7. Dell Venue 11 Pro Speakers Replacement: adım 7, 1 resimden 1.
    • There are adhesive strips between the device and the two ribbon cables we disconnected. Pull each cable away from the device just enough to break the adhesive bonds.
  8. Dell Venue 11 Pro Speakers Replacement: adım 8, 3 resimden 1. Dell Venue 11 Pro Speakers Replacement: adım 8, 3 resimden 2. Dell Venue 11 Pro Speakers Replacement: adım 8, 3 resimden 3.
    • Use your pin punch driver to push into the hole on the sim card, then pull out the sim tray.
  9. Dell Venue 11 Pro Speakers Replacement: adım 9, 3 resimden 1. Dell Venue 11 Pro Speakers Replacement: adım 9, 3 resimden 2. Dell Venue 11 Pro Speakers Replacement: adım 9, 3 resimden 3.
    • Insert your plastic opening tool between the screen and frame, and run the tool around the edges to separate the frame from the tablet.
  10. Dell Venue 11 Pro Speakers Replacement, Speakers: adım 10, 1 resimden 1.
    • Locate the right and left speakers to be replaced. For this guide, we will start with the left speaker, then the right speaker.
    • If you are replacing the motherboard by itself, then skip steps 17 and 19.
  11. Dell Venue 11 Pro Speakers Replacement: adım 11, 3 resimden 1. Dell Venue 11 Pro Speakers Replacement: adım 11, 3 resimden 2. Dell Venue 11 Pro Speakers Replacement: adım 11, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Using a pair of tweezers, detach the red and white cable connector from the circuit board.
    • The laptop is rotated 130 degrees counterclockwise for better viewing.
  12. Dell Venue 11 Pro Speakers Replacement: adım 12, 2 resimden 1. Dell Venue 11 Pro Speakers Replacement: adım 12, 2 resimden 2.
    • Once the cable has been detached, use your fingers to lift the right speaker upwards to remove it.
  13. Dell Venue 11 Pro Speakers Replacement: adım 13, 3 resimden 1. Dell Venue 11 Pro Speakers Replacement: adım 13, 3 resimden 2. Dell Venue 11 Pro Speakers Replacement: adım 13, 3 resimden 3.
    • On the right side, use a pair of tweezers to detach the red and white cables from the connector.
    • This device is rotated 130 degrees clockwise for better viewing.
  14. Dell Venue 11 Pro Speakers Replacement: adım 14, 1 resimden 1.
    • Lift the right speaker upwards using your fingers to remove it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Carolina Gushi
339 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G1, Nance Fall 2017 USF Tampa, Team S3-G1, Nance Fall 2017 üyesi
USFT-NANCE-F17S3G1
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 20
Her zaman: 494
