Ana içeriğe geç
Dell Venue 7 Battery Replacement
Neye ihtiyacın var
  1. Dell Venue 7 Battery Replacement, Rear Case: adım 1, 2 resimden 1. Dell Venue 7 Battery Replacement, Rear Case: adım 1, 2 resimden 2.
    • Use a spudger or your fingers to pry off the back case.
    • If your case is badly damaged, use caution because the fragments may be sharp.
  2. Dell Venue 7 Battery Replacement, Battery: adım 2, 1 resimden 1.
    • Gently disconnect the battery from the motherboard using your fingers or a pair of tweezers.
  3. Dell Venue 7 Battery Replacement: adım 3, 1 resimden 1.
    • Remove the battery by pulling it from the edges and carefully peeling it off of the base.
    • There is adhesive keeping the battery in place, so don't be afraid to use a little extra force.
    • Do not bend or warp the battery in any way as it can be a fire hazard.
Sonuç
chaveza
101 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 11-4, Blackwell Winter 2015 USF Tampa, Team 11-4, Blackwell Winter 2015 üyesi
USFT-BLACKWELL-W15S11G4
4 Üyeler
10 adet Kılavuz yazıldı
4 Yorum
I am purchase dell vaneu 7 8gb internal memory like_ion battery 15.17 wh EU 4100 price
Avind Kumar agrawal - Yanıt
Dell vanue 7 tablat I want like_battery 15.17wh EU 4100 mah
Prices dell venue 7 li_I on battery 15.17 wh EU 4100mah
From were to purchase battery
shriyash Mhatre - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 12
Her zaman: 7,372
