Ana içeriğe geç
Dell Venue 7 Motherboard Replacement
Neye ihtiyacın var
  1. Dell Venue 7 Motherboard Replacement, Rear Case: adım 1, 2 resimden 1. Dell Venue 7 Motherboard Replacement, Rear Case: adım 1, 2 resimden 2.
    • Use a spudger or your fingers to pry off the back case.
    • If your case is badly damaged, use caution because the fragments may be sharp.
  2. Dell Venue 7 Motherboard Replacement, Battery: adım 2, 1 resimden 1.
    • Gently disconnect the battery from the motherboard using your fingers or a pair of tweezers.
  3. Dell Venue 7 Motherboard Replacement: adım 3, 1 resimden 1.
    • Remove the battery by pulling it from the edges and carefully peeling it off of the base.
    • There is adhesive keeping the battery in place, so don't be afraid to use a little extra force.
    • Do not bend or warp the battery in any way as it can be a fire hazard.
  4. Dell Venue 7 Motherboard Replacement, Rear Facing Camera: adım 4, 1 resimden 1.
    • Use a spudger to disconnect the camera from the motherboard.
  5. Dell Venue 7 Motherboard Replacement: adım 5, 1 resimden 1.
    • Remove the camera from the device.
  6. Dell Venue 7 Motherboard Replacement, Speaker: adım 6, 2 resimden 1. Dell Venue 7 Motherboard Replacement, Speaker: adım 6, 2 resimden 2.
    • Use a spudger to remove the ribbon cable that is around the speaker wire.
  7. Dell Venue 7 Motherboard Replacement: adım 7, 2 resimden 1. Dell Venue 7 Motherboard Replacement: adım 7, 2 resimden 2.
    • Disconnect the speaker wire from the motherboard by prying the connector upwards with the spudger.
  8. Dell Venue 7 Motherboard Replacement: adım 8, 1 resimden 1.
    • Remove the plastic covering on the speaker.
  9. Dell Venue 7 Motherboard Replacement: adım 9, 2 resimden 1. Dell Venue 7 Motherboard Replacement: adım 9, 2 resimden 2.
    • Gently pull on the wire and remove the speaker.
  10. Dell Venue 7 Motherboard Replacement, Motherboard: adım 10, 3 resimden 1. Dell Venue 7 Motherboard Replacement, Motherboard: adım 10, 3 resimden 2. Dell Venue 7 Motherboard Replacement, Motherboard: adım 10, 3 resimden 3.
    • Disconnect the two remaining connections on the motherboard.
    • To remove the first connector, lift up the clasp and remove the ribbon cable.
    • To remove the second one, use a spudger to gently pry the connector from the motherboard.
  11. Dell Venue 7 Motherboard Replacement: adım 11, 2 resimden 1. Dell Venue 7 Motherboard Replacement: adım 11, 2 resimden 2.
    • Remove all 8 of the 2.1mm Phillips head screws from the motherboard.
  12. Dell Venue 7 Motherboard Replacement: adım 12, 1 resimden 1.
    • Lift and remove the motherboard from the device.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Stephen Rousseau
663 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 11-4, Blackwell Winter 2015 USF Tampa, Team 11-4, Blackwell Winter 2015 üyesi
USFT-BLACKWELL-W15S11G4
4 Üyeler
10 adet Kılavuz yazıldı
2 Yorum
unable to open the lock, can the mother board be changed
Amitabh Mishra - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 4,416
