Ana içeriğe geç
Dell Venue 7 Rear Facing Camera Replacement
Neye ihtiyacın var
  1. Dell Venue 7 Rear Facing Camera Replacement, Rear Case: adım 1, 2 resimden 1. Dell Venue 7 Rear Facing Camera Replacement, Rear Case: adım 1, 2 resimden 2.
    • Use a spudger or your fingers to pry off the back case.
    • If your case is badly damaged, use caution because the fragments may be sharp.
  2. Dell Venue 7 Rear Facing Camera Replacement, Battery: adım 2, 1 resimden 1.
    • Gently disconnect the battery from the motherboard using your fingers or a pair of tweezers.
  3. Dell Venue 7 Rear Facing Camera Replacement: adım 3, 1 resimden 1.
    • Remove the battery by pulling it from the edges and carefully peeling it off of the base.
    • There is adhesive keeping the battery in place, so don't be afraid to use a little extra force.
    • Do not bend or warp the battery in any way as it can be a fire hazard.
  4. Dell Venue 7 Rear Facing Camera Replacement, Rear Facing Camera: adım 4, 1 resimden 1.
    • Use a spudger to disconnect the camera from the motherboard.
  5. Dell Venue 7 Rear Facing Camera Replacement: adım 5, 1 resimden 1.
    • Remove the camera from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Stephen Rousseau
663 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 11-4, Blackwell Winter 2015 USF Tampa, Team 11-4, Blackwell Winter 2015 üyesi
USFT-BLACKWELL-W15S11G4
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 5
Her zaman: 456
