Ana içeriğe geç
Dell Venue 8 7840 Battery Replacement
Neye ihtiyacın var
  1. Dell Venue 8 7840 Battery Replacement, Screen: adım 1, 1 resimden 1.
    • Make sure your device is turned off. Leaving it turned on may cause an electric shock.
    • Face the device with the screen towards you.
  2. Dell Venue 8 7840 Battery Replacement: adım 2, 1 resimden 1.
    • With a plastic opening tool, pry open the bottom left corner of the screen.
    • The screen is tightly attached to the tablet, so you may have to use a metal spudger to pry it open if the plastic spudger does not do the task.
  3. Dell Venue 8 7840 Battery Replacement: adım 3, 1 resimden 1.
    • Next, pry open the top left corner of the screen.
  4. Dell Venue 8 7840 Battery Replacement: adım 4, 1 resimden 1.
    • Then, pry open the top right corner of the screen.
  5. Dell Venue 8 7840 Battery Replacement: adım 5, 1 resimden 1.
    • Lastly, pry open the bottom right corner of the screen.
  6. Dell Venue 8 7840 Battery Replacement: adım 6, 1 resimden 1.
    • Once you have pried open all the corners of the tablet, carefully open the screen from the right side of the tablet.
    • Do not try and open the screen from the left side of the tablet, because the screen is attached on the left side of the tablet; doing this can damage the tablet.
  7. Dell Venue 8 7840 Battery Replacement: adım 7, 1 resimden 1.
    • Once the tablet is opened, locate the connector.
  8. Dell Venue 8 7840 Battery Replacement: adım 8, 1 resimden 1.
    • Disconnect the connector from the tablet.
  9. Dell Venue 8 7840 Battery Replacement, Battery: adım 9, 1 resimden 1.
    • Unscrew the eight 7 mm Philips #1 screws.
    • After the screws are unscrewed, you can take off the silver cover.
  10. Dell Venue 8 7840 Battery Replacement: adım 10, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Using tweezers, disconnect the battery from the tablet.
    • After disconnecting the battery, you can remove the battery from the tablet.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Donnelle January
429 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 6-5, Remmell Fall 2016 USF Tampa, Team 6-5, Remmell Fall 2016 üyesi
USFT-REMMELL-F16S6G5
3 Üyeler
6 adet Kılavuz yazıldı
8 Yorum
Hi
I need some advice from you on replacing battery for Venue 7840.
Is the display assembly attached to the main body with sticky glue? Is it helpful to heat up the edges of the display assembly with a dryer or heat gun before removing it?
Thanks in advance
dengzc
dengzc - Yanıt
Yes it is attached with glue, removing the screen as described will likely result in a wrecked screen unless you're a magician. Also, the battery seems to be glued to the back of the device, making removal challenging. And by that I mean almost impossible without destroying it.
Alex Gehrig - Yanıt
Hi,
Assuming you are already using replacement battery, please share the replacement battery yo used. Also, how is the performance of current battery.
And also let us know if you have any advice or suggestion for battery and if it is worth to replace battery.
Pankaj - Yanıt
Can anyone who has actually performed this replacement discuss how difficult or easy it actually was? Did you use only the tools listed or was the heat gun necessary/useful? Does the tablet with a replacement battery accept a full charge and fully discharge before shutting down? Does the referenced glue that Alex mentioned actually make this replacement as unlikely to be successful as indicated. I ordered 2 new batteries from Chinese vendor via Ebay. They both arrived with comprehensive tool kits to execute the replacement including suction cups for the screen. I have a heat gun and will most likely do this in the next 2 weeks on 2 Venue 7840’s. I’ll re-post with results.
Jonathan “JTau” Tauber - Yanıt
I performed this replacement. I used a heat gun - the screen was still difficult to remove, and I’m not sure if the heat helped or not. I also used suction pliers made for pulling screens apart (you can find these for around $12 or so). If you use suction pliers, you hold the tablet in portrait mode and suction at top right corner keeping the screen pinched together at bottom left corner (reason: the ribbon cable connecting the screen to the tablet is in the bottom left corner and you don’t want to damage that when suctioning the screen away from the body). I also used old playing cards to help work the screen loose from the body (old playing cards work infinitely better than the pry tools in my opinion). The screen is held in place by 1mm double sided adhesive tape (you will want to order a roll of this for putting the tablet back together, so be sure you have some ready, it’s not expensive).
Getting the old battery out is a real pain as it’s stuck to the body using a couple very thick strips of double sided flexible adhesive tape, and this is where you will want to make liberal use of the heat gun on the back side of the tablet. Be very careful pulling the old battery out - lithium ion batteries are known to combust if they are traumatized too much. I’d recommend wearing safety glasses and have a fire extinguisher handy.
After getting it all back together, the tablet accepts a full charge, and I can now run it down to 1% before the tablet turns off on it’s own. I’m super happy with the battery swap.
krayj -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 20
Her zaman: 6,849
