Ana içeriğe geç
Dell Venue 8 7840 Screen Replacement
Neye ihtiyacın var
  1. Dell Venue 8 7840 Screen Replacement, Screen: adım 1, 1 resimden 1.
    • Make sure your device is turned off. Leaving it turned on may cause an electric shock.
    • Face the device with the screen towards you.
  2. Dell Venue 8 7840 Screen Replacement: adım 2, 1 resimden 1.
    • With a plastic opening tool, pry open the bottom left corner of the screen.
    • The screen is tightly attached to the tablet, so you may have to use a metal spudger to pry it open if the plastic spudger does not do the task.
  3. Dell Venue 8 7840 Screen Replacement: adım 3, 1 resimden 1.
    • Next, pry open the top left corner of the screen.
  4. Dell Venue 8 7840 Screen Replacement: adım 4, 1 resimden 1.
    • Then, pry open the top right corner of the screen.
  5. Dell Venue 8 7840 Screen Replacement: adım 5, 1 resimden 1.
    • Lastly, pry open the bottom right corner of the screen.
  6. Dell Venue 8 7840 Screen Replacement: adım 6, 1 resimden 1.
    • Once you have pried open all the corners of the tablet, carefully open the screen from the right side of the tablet.
    • Do not try and open the screen from the left side of the tablet, because the screen is attached on the left side of the tablet; doing this can damage the tablet.
  7. Dell Venue 8 7840 Screen Replacement: adım 7, 1 resimden 1.
    • Once the tablet is opened, locate the connector.
  8. Dell Venue 8 7840 Screen Replacement: adım 8, 1 resimden 1.
    • Disconnect the connector from the tablet.
Sonuç
Donnelle January
429 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 6-5, Remmell Fall 2016 USF Tampa, Team 6-5, Remmell Fall 2016 üyesi
USFT-REMMELL-F16S6G5
3 Üyeler
6 adet Kılavuz yazıldı
3 Yorum
i wanted to replace the battery but dont know how to pry the screen open, is it attached with glue? thanks in advance.
dengzc - Yanıt
Where can I find a replacement screen for this device?
Karim Mohamed - Yanıt
Is the OLED connected with EDP 30=pin FPC?
Ron King - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 1,389
