Ana içeriğe geç
Dell Venue 8 Battery Replacement
Neye ihtiyacın var
  1. Dell Venue 8 Battery Replacement, Rear Case/Midframe: adım 1, 1 resimden 1.
    • Hold the device with the screen facing up. Gently wedge your plastic opening tool into the crease, and run it along the perimeter of the case
    • You will hear click sounds as the clips unhinge
    • Remove the back panel of the device.
  2. Dell Venue 8 Battery Replacement: adım 2, 3 resimden 1. Dell Venue 8 Battery Replacement: adım 2, 3 resimden 2. Dell Venue 8 Battery Replacement: adım 2, 3 resimden 3.
    • Remove the 14 screws with the T-5 Torx screwdriver. (11 black 3.6mm screws, and three 4.45mm screws)
    • The silver screws are marked with an "S" or a sticker [S1.6(Silver)] See the corrected image
    • 4.45mm Silver screws
    • 3.6mm Black screws
    • Gently snap the perimeter clips open, and remove the internal plastic case.
  3. Dell Venue 8 Battery Replacement, Battery: adım 3, 1 resimden 1.
    • Unclip the power clip from the motherboard by pulling down gently towards the bottom of the tablet.
  4. Dell Venue 8 Battery Replacement: adım 4, 1 resimden 1.
    • Gently pry the battery away from the device with the plastic opening tool to remove it.
    • The battery is held on to the tablet by a light adhesive
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Andrea
1.071 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-2, Leahy Winter 2015 USF Tampa, Team 9-2, Leahy Winter 2015 üyesi
USFT-LEAHY-W15S9G2
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 30
Her zaman: 12,458
