Giriş
If your camera isn't functioning properly, not showing a display, or looks cracked or foggy, it may need to be replaced. In this guide we will be replacing the front-facing camera.
Neye ihtiyacın var
Hold the device with the screen facing up. Gently wedge your plastic opening tool into the crease, and run it along the perimeter of the case
Remove the back panel of the device.
The front-facing camera is located just above the rear-facing camera.
Pull the connection tab up, unclipping it.
