Ana içeriğe geç
Dell Venue 8 Speaker Replacement
Neye ihtiyacın var
  1. Dell Venue 8 Speaker Replacement, Rear Case/Midframe: adım 1, 1 resimden 1.
    • Hold the device with the screen facing up. Gently wedge your plastic opening tool into the crease, and run it along the perimeter of the case
    • You will hear click sounds as the clips unhinge
    • Remove the back panel of the device.
  2. Dell Venue 8 Speaker Replacement: adım 2, 3 resimden 1. Dell Venue 8 Speaker Replacement: adım 2, 3 resimden 2. Dell Venue 8 Speaker Replacement: adım 2, 3 resimden 3.
    • Remove the 14 screws with the T-5 Torx screwdriver. (11 black 3.6mm screws, and three 4.45mm screws)
    • The silver screws are marked with an "S" or a sticker [S1.6(Silver)] See the corrected image
    • 4.45mm Silver screws
    • 3.6mm Black screws
    • Gently snap the perimeter clips open, and remove the internal plastic case.
  3. Dell Venue 8 Speaker Replacement, Speaker: adım 3, 1 resimden 1.
    • Using your plastic opening tool, unclip the speaker connection from the logic board.
    • Caution: Pull directly up, not out, on the connection
  4. Dell Venue 8 Speaker Replacement: adım 4, 1 resimden 1.
    • Remove the speaker by placing using your plastic opening tool in the gap on the top of the speaker and prying it up.
    • The speaker is held on by light adhesive
Sonuç
Andrea
1.071 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-2, Leahy Winter 2015 USF Tampa, Team 9-2, Leahy Winter 2015 üyesi
USFT-LEAHY-W15S9G2
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 705
