Ana içeriğe geç
Dell Venue Pro Volume Button Replacement
Neye ihtiyacın var
    1. Dell Venue Pro Volume Button Replacement, Back Cover: adım 1, 1 resimden 1.
      • Slide the back cover up.
      • Lift the back cover away from the device completely.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Venue Pro Volume Button Replacement, Battery: adım 2, 2 resimden 1. Dell Venue Pro Volume Button Replacement, Battery: adım 2, 2 resimden 2.
      • Use your finger to lift the battery using the notch in the upper left corner of the compartment.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Venue Pro Volume Button Replacement, Volume Button: adım 3, 1 resimden 1.
      • Remove the Back Cover
      • Slide and lift the back cover off the phone. (Use the existing Back Cover Removal guide as reference)
      FixBot'a Sor
      Yorum Ekle
    2. Dell Venue Pro Volume Button Replacement: adım 4, 1 resimden 1.
      • Remove the Battery
      • Lift the battery out of its compartment and set it aside.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Venue Pro Volume Button Replacement: adım 5, 2 resimden 1. Dell Venue Pro Volume Button Replacement: adım 5, 2 resimden 2.
      • Remove the Midframe Screws
      • Use a Phillips #00 screwdriver to remove the 4.57 mm screws securing the midframe to the phone.
      • Keep track of each screw and its original location to ensure correct reassembly.
      • Mixing screw lengths can damage internal components during reassembly.
      FixBot'a Sor
      Yorum Ekle
    4. Dell Venue Pro Volume Button Replacement: adım 6, 2 resimden 1. Dell Venue Pro Volume Button Replacement: adım 6, 2 resimden 2.
      • Insert a plastic opening tool into the seam between the midframe and phone body.
      • Gently twist the tool to release the clips around the edges.
      • Once all clips have disengaged, pull the midframe upward to remove it completely.
      • If the midframe resists, continue sliding the tool along the seam until every clip releases.
      FixBot'a Sor
      Yorum Ekle
    5. Dell Venue Pro Volume Button Replacement: adım 7, 1 resimden 1.
      • Expose the Motherboard
      • With the midframe removed, the motherboard should now be fully visible.
      • Identify the following components before continuing:
      • SIM card reader near the top of the device
      • Metal shielding covering the center of the motherboard
      • Micro-USB charging port at the bottom
      • Secondary daughterboard connection on the left side
      • Set the midframe aside.
      FixBot'a Sor
      Yorum Ekle
    6. Dell Venue Pro Volume Button Replacement: adım 8, 2 resimden 1. Dell Venue Pro Volume Button Replacement: adım 8, 2 resimden 2.
      • Disconnect Internal Cables
      • At this point, the motherboard should be fully visible, as shown in your reference photos. You should see:
      • Disconnect the following cables:
      • Display cable
      • Any remaining flex cables attached to the motherboard
      • Lift connectors straight up—do not pull on the cables.
      FixBot'a Sor
      Yorum Ekle
    7. Dell Venue Pro Volume Button Replacement: adım 9, 2 resimden 1. Dell Venue Pro Volume Button Replacement: adım 9, 2 resimden 2.
      • Remove the Motherboard Screws
      • Use a Phillips #00 screwdriver to remove the 2.68 mm screws securing the motherboard to the frame.
      • Screws are located near:
      • The bottom right corner (charging port area)
      • The middle left side
      • The top of the motherboard
      • Set all screws aside.
      • Using longer screws in motherboard locations can cause permanent damage.
      FixBot'a Sor
      Yorum Ekle
    8. Dell Venue Pro Volume Button Replacement: adım 10, 2 resimden 1. Dell Venue Pro Volume Button Replacement: adım 10, 2 resimden 2.
      • Starting from the top edge, gently lift the motherboard up and away from the phone housing.
      • The micro-USB charging port may fit snugly in its opening. Lift carefully to avoid bending the board.
      • Once free, remove the motherboard from the device. Set the motherboard aside.
      • Do not flex or twist the motherboard during removal.
      FixBot'a Sor
      Yorum Ekle
    9. Dell Venue Pro Volume Button Replacement: adım 11, 2 resimden 1. Dell Venue Pro Volume Button Replacement: adım 11, 2 resimden 2.
      • Remove the Volume Button Assembly
      • Locate the volume button assembly along the side of the phone frame.
      • Lift the volume button assembly out of its recess.
      • The button contacts are delicate. Remove the assembly carefully.
      FixBot'a Sor
      Yorum Ekle
    10. Dell Venue Pro Volume Button Replacement: adım 12, 1 resimden 1.
      • Install the New Volume Button Assembly
      • Place the replacement volume button assembly into the phone frame.
      • Ensure it sits flush and aligns correctly with the external button openings.
      FixBot'a Sor
      Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 25
Her zaman: 124
