Ana içeriğe geç
Dell Vostro 1000 Memory Module Replacement
Neye ihtiyacın var
  1. Dell Vostro 1000 Memory Module Replacement, Battery: adım 1, 1 resimden 1.
    • Slide and hold the battery-bay latch release on the bottom of the computer, and then lift the battery from the bay.
    FixBot'a Sor
    Yorum Ekle
  2. Dell Vostro 1000 Memory Module Replacement, Memory Module: adım 2, 1 resimden 1.
    • loosen the captive screws on the memory module cover, and then remove the memory module cover.
    FixBot'a Sor
    Yorum Ekle
  3. Dell Vostro 1000 Memory Module Replacement: adım 3, 1 resimden 1.
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory-module securing clips.
    • NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
    • Use your fingertips to carefully spread apart the memory-module securing clips on each end of the memory module connector until the module pops up.
    • Remove the module from the connector.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Johnathan Hammond
46.149 İtibar
408 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
45 Üyeler
2.003 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 23
Her zaman: 421
