Ana içeriğe geç
Parçalar
Hiçbir parça belirtilmedi.
  1. Slide the battery latches apart while at the same time slipping your forefingers into the groove at the center of the battery and pushing outward to disengage the battery from the computer. Lift the battery from the computer.
    • Slide the battery latches apart while at the same time slipping your forefingers into the groove at the center of the battery and pushing outward to disengage the battery from the computer.
    • Lift the battery from the computer.
  2. Remove the six screws that secure the access panel to the computer. Remove the access panel from the computer.
    • Remove the six screws that secure the access panel to the computer.
    • Remove the access panel from the computer.
  3. Use your fingertips to carefully spread apart the securing clips on each end of the first memory module connector until the first module pops up. Slide the first memory module from its socket and remove the module from the computer.
    • Use your fingertips to carefully spread apart the securing clips on each end of the first memory module connector until the first module pops up.
    • Slide the first memory module from its socket and remove the module from the computer.
Sonuç
Johnathan Hammond
36.011 İtibar
408 adet Kılavuz yazıldı
Takım
Informative Technologies Inc. Informative Technologies Inc. üyesi
Community
15 Üyeler
930 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 2
Son 30 Gün: 2
Her zaman: 17
