Ana içeriğe geç
Dell Vostro 1310 Memory Module Replacement
Neye ihtiyacın var
    1. Dell Vostro 1310 Memory Module Replacement, Battery: adım 1, 1 resimden 1.
      • Slide the battery lock to the open position. {2}
      • Slide the battery latch release to the open position. (You may need to hold the latch release in the open position while removing the battery.){3}
      • Slide the battery out of the battery bay. {1}
      FixBot'a Sor
      Yorum Ekle
    1. Dell Vostro 1310 Memory Module Replacement, Memory Module: adım 2, 1 resimden 1.
      • Remove the M2.5 x 5-mm screw that secures the memory cover, and remove the cover and set it aside.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Vostro 1310 Memory Module Replacement: adım 3, 1 resimden 1.
      • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
      • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
      • Remove the memory module from the connector.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Johnathan Hammond
46.158 İtibar
408 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
45 Üyeler
4.987 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 403
