Ana içeriğe geç
Dell Vostro 1320 USB Port Replacement
Neye ihtiyacın var
  1. Dell Vostro 1320 USB Port Replacement, USB Port: adım 1, 1 resimden 1.
    • Remove the battery from the computer.
  2. Dell Vostro 1320 USB Port Replacement: adım 2, 1 resimden 1.
    • Remove all visible screws from the bottom of the computer.
  3. Dell Vostro 1320 USB Port Replacement: adım 3, 3 resimden 1. Dell Vostro 1320 USB Port Replacement: adım 3, 3 resimden 2. Dell Vostro 1320 USB Port Replacement: adım 3, 3 resimden 3.
    • Use a metal spudger to remover the covers of each section that you removed screws from.
    • Once the cover is removed from the hard drive remove the hard drive by gently tugging it out.
  4. Dell Vostro 1320 USB Port Replacement: adım 4, 1 resimden 1.
  5. Dell Vostro 1320 USB Port Replacement: adım 5, 3 resimden 1. Dell Vostro 1320 USB Port Replacement: adım 5, 3 resimden 2. Dell Vostro 1320 USB Port Replacement: adım 5, 3 resimden 3.
    • You must first unscrew the screws holding the wire in place.
    • Unhook the wire that the metal spudger is pointing at.
  6. Dell Vostro 1320 USB Port Replacement: adım 6, 1 resimden 1.
  7. Dell Vostro 1320 USB Port Replacement: adım 7, 2 resimden 1. Dell Vostro 1320 USB Port Replacement: adım 7, 2 resimden 2.
    • Undo the screws holding the screen to the computer base.
  8. Dell Vostro 1320 USB Port Replacement: adım 8, 1 resimden 1.
    • Unplug the wires connecting the screen to the base.
    • The screen should come free and is able to be removed completely.
  9. Dell Vostro 1320 USB Port Replacement: adım 9, 2 resimden 1. Dell Vostro 1320 USB Port Replacement: adım 9, 2 resimden 2.
    • Unplug the two blue labeled wires.
  10. Dell Vostro 1320 USB Port Replacement: adım 10, 3 resimden 1. Dell Vostro 1320 USB Port Replacement: adım 10, 3 resimden 2. Dell Vostro 1320 USB Port Replacement: adım 10, 3 resimden 3.
    • Detach the black plastic cover by loosening it with a metal spudger.
  11. Dell Vostro 1320 USB Port Replacement: adım 11, 1 resimden 1.
    • Unplug the wire that the metal spudger is pointing to.
  12. Dell Vostro 1320 USB Port Replacement: adım 12, 1 resimden 1.
    • Unscrew the USB port.
  13. Dell Vostro 1320 USB Port Replacement: adım 13, 2 resimden 1. Dell Vostro 1320 USB Port Replacement: adım 13, 2 resimden 2.
    • Gently lift out the USB port.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 622
