Ana içeriğe geç
Dell Vostro 14 3468 Memory Module Replacement
Neye ihtiyacın var
  1. Dell Vostro 14 3468 Memory Module Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the release latch to unlock the battery [1].
    • Remove the battery from the computer [2].
  2. Dell Vostro 14 3468 Memory Module Replacement, Optical-Disk Drive: adım 2, 1 resimden 1.
    • Remove the screw that secures the optical drive to the computer [1].
    • Using a plastic scribe, push the tab to release the optical drive [2].
    • Slide the optical drive out of the computer [3].
  3. Dell Vostro 14 3468 Memory Module Replacement, KeyBoard: adım 3, 1 resimden 1.
    • Release the keyboard by prying on the keyboard release tabs using a plastic scribe [1].
    • Slide and lift the keyboard to access the keyboard connector cable under the keyboard [2].
  4. Dell Vostro 14 3468 Memory Module Replacement: adım 4, 1 resimden 1.
    • Disconnect the keyboard cable from the system board.
    • Lift the keyboard cable to remove it from the computer.
  5. Dell Vostro 14 3468 Memory Module Replacement, Base Cover: adım 5, 1 resimden 1.
    • Disconnect the optical drive connector and lift it to remove it from the system board [1].
    • Remove the screws inside the palmrest [2].
  6. Dell Vostro 14 3468 Memory Module Replacement: adım 6, 1 resimden 1.
    • Remove the screws that secure the base cover to the computer
  7. Dell Vostro 14 3468 Memory Module Replacement: adım 7, 1 resimden 1.
    • Pry the edges of the base cover [1].
    • Lift the base cover and remove it from the computer [2].
  8. Dell Vostro 14 3468 Memory Module Replacement, Memory Module: adım 8, 1 resimden 1.
    • Pull the clips securing the memory module until the memory module pops up [1].
    • Remove the memory module from the system board [2].
Sonuç
Bir başkası bu kılavuzu tamamladı.
Johnathan Hammond
45.237 İtibar
408 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
43 Üyeler
1.985 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 952
